glfredrick
- January 25, 2003
- Sheboygan, WI
- 2014 Explorer Limited
Diesel.
very good, sir. thank you. any other little tips you'd like to throw out there, since it looks like i'm building a clone of your truck? lol.Diesel.
Drive it like you stold it???
Just kidding, actually. I took my 'Sploder through a lot of stuff for having a budget build suspension, and it was VERY faithful. I never broke a single suspension or drivetrain component over all the trail miles I ran.
I did have to replace a few transmissions, but that comes with the turf with the known issues with the A4LD.
Otherwise, I mostly walked up stuff and used the throttle only when I had to. Keeps the truck alive a LOT longer.
that's pretty much how i drove my last one. it had the a4ld, and i babied it. this one has the m50d, so i'm sure i'll be burning through a few clutches. lol.
i read that in another of your posts too. i kept that exact phrase "just in case" in my mind when i took the new ex out to the trails for the first time. i caught myself resting my foot on the clutch when we first got in there, and remembered reading that... my foot was only on the clutch to shift and stop from that point on. i'm not new to wheelin at all, but this IS my first 5 speed rig... it's quite a lot different.the trick to off-roading with a clutch is to have the guts to let your left foot lay on the floor instead of resting on the clutch pedal "just in case."
I've watched guys struggling to get up an obstacle, and watched where they have their left leg (in open door Jeeps -- same principle applies). I get on them to take their foot off the clutch, and it is wild... Truck goes right up stuff. That little bit of slip that happens when the foot even brushes up against the clutch pedal will cause bounce and tire hop, not to mention all sort of clutch and throwout bearing wear.
so i've seen. the times when i switched into low gear, i'd start out in second gear (first seems like it could pull a house off it's foundation!), and most times, i wouldn't even use the clutch. i could go as slow as a crawl or as fast as 10mph or so without ever touching the clutch. it was surprisingly easy.The trick to a clutch is LOW gears.
do you need to do anything with the steering??
pitman arm?
can you make the quick disconnect for the rear swaybar? im really liking this setup but my x is my main rig. i like my wheelin but i need it for my dd. so i dont want to lose to much drivability.
thanks for the awsome info. cant wait till i get it done. everybody around here are 'yota guys. cant wait to show them up.
instead of drilling out the bushing, would shaving the pin down alittle work also?
yeah. i have been able to keep up with '85 yota with 4 in susp. on 32s and a '95 with 4 in on 33s. granted i need to move my air intake... i keep flooding it out.
you got any other qwik/cheap tricks or mods?
