Well, I just got back from California on a business trip and see there have been some replies.
LOGJOCKY,
How's things going with the CB and antenna stuff.
If you are going to mount the antenna to the rack watch out for the grounding. As scratch 95 says the antenna is the most important part and it has to grounded to work properly. Why not consider a magnet mount, you can mount it just in front of the rack and it will have all the ground it needs from the magnet. Usually with CBs the best antenna location is as high and centered on the vehicle as you can be. In the case of Fords, the roof is better because of the fuel pump noise; the body of the vehicle shields the antenna a little.
How do you intend to use your CB? Trail use/local talk or do you want to talk to the world?
Trail use almost any antenna will do, I use a 24" Wilson Flexi Whip for the trail and a Wilson 2000 for the road with a Uniden 538 radio w/power mic. I have to turn the mic to the lowest setting on the trail but on a road run I can talk to people a mile or more away if everything else is quiet.
So what does all this mean, determine your use, buy a good name brand radio, the smallest one will work just as well as the top of the line. Buy a good antenna, as scratch 95 stated, and you should have no problems. Don’t buy Radio Shack, Cheap Stuff.
Oh Ya, if you want to talk to the world, become a HAM. If you do want to be a HAM let me or any other HAM know, we can set you up.
scratched 95,
Just to carry on a little, my comments from previous replies did not mention that the radio was the most important part. I only stated to buy a Uniden or Cobra to keep the radio inexpensive but not cheap and I asked a couple of questions about how LOGJOCKY would be using his CB and to base his antenna purchase on his use factor because a good CB antenna can run 70 or 80 dollars.
Yes the antenna is the most import part of the CB radio system and yes that is where he should spend any extra money but on the other hand LOGJOCKY needs to determine his use first then decide how much he has to spend and then buy his equipment. 73.
