jscotty467
- May 29, 2009
- Orlando, Fl
- 94 XLT
Another newbie checking in. I am new to forums and new to Explorers. Recently aquired a '94 XLT with 157K on it and a few problems. Currently I am trying to correct a headlamp issue that I believe is related to the multi function switch but thought I would see if anyone out there has run into this problem. Headlights on, high beam indicator always lit. When the switch stalk is pushed away (high beam?) the lights dim to almost nill. When the stalk is pulled towards driver (low beam?) the lamps are bright, flash to pass function is minimal. I have had a hard time finding a decent schematic. The vehicle does not have auto headlamps or DRL (as best I can tell). The one schematic I do have shows the dimmer switch as a standalone switch but I am pretty sure that it is integrated into the multifunction switch...any suggestions are welcome.
