Huricane
- December 19, 2007
- St Louis
- 95 ranger
hello, i just purchased a 95 ranger 2wd with a 4.0 and auto, which i presume is the 4r44e. the truck has well over 250,000 miles on it, the seller stated that the transmission had been "gone through" not long ago. what all that entaled, i dont know and neither did he. it was running poorly when i bought it and idling very high and would slam into gear when you shifted. it seems as though it has no 1st gear and no overdrive.
whether you manually shift into 1st or put it into d, it takes off in 2nd. when you get on the highway, it wont shift into overdrive, and also wont kickdown a gear if you floor it. the od off light doesnt function either, i replaced the bulb in the dash and also traced down the faulty switch in the gear selector, which is now working properly, but it doesnt turn the light on when you press the button.
i adjusted the bands today and you can sometimes get it to go into first when slowing down, but not all the time. when you get on the gas it seems to go into 2nd gear. i havent pulled the pan yet, but thought i would see if anybody here has any advice before i tear into it.
thanks
thanks
