EMBPilot
- November 29, 2006
- Jersey Shore
- 2007 Ranger 4x4 XLT 4.0L
Hey guys wonder if anyone can point me in a direction here, im a little stumped. I checked all the brake lamp fuses (acutally just the brake pedal position fuses), and they checked fine on the meter. I did not check the lamp fuses cause all three lamps in the back are not coming on.
could the switch have failed? i can hear the switch clicking when you depress the brake, the harness is on there good and tight. not sure what else i can check, or how to check the switch itself??
so the stop lights L and R, and the High mount does not work... the parking lamps (rear) DO work. the truck does have the factory tow package. (not sure of that matters).
thanks again!
Kevin
thanks again!
Kevin
