Diemondrio63
- September 14, 2009
- Orwigsburg, PA
- 1989 B2,1995 Eddie Bauer
I have big time brake issues.
I noticed that the pedal was getting spongy so I figured it was time to bleed the system. I started at the right rear but stopped after finding that the bleeder was snapped off, as well as the left one, the fronts were fine. I changed the rear calipers with new ones and then the trouble started!
After what I thought was a successful bleed job I started the truck and went to move it to find that the pedal went to the floor! I then shut if off and had a firm pedal. I tried bleeding the brakes again with the engine running but never was able to get much of a pedal to do anything with. It seemed that I had back brakes only so after confirming this I went and changed the master cylinder and the brake booster. Guess what... same damn thing!
I'm now figuring it's something with the ABS system. I do have 4 wheel ABS on this thing. I'm not getting any codes nor is the ABS light on. I also noticed that when the engine is off and you push the pedal down about half way the ABS relay is clicking... any ideas???
Mark
Mark
