Sugo Kaidan
- October 4, 2008
- '94 explorer sport
Right now on my 94 Explorer there are no brakes, I changed the Master Cylinder on it because the brakes were spongy and lost pressure whenever I tried to drive it any distance. Right now I'm trying to figure out how to turn off the ABS for it, I've unplugged the relays and fuses and the pedal kept going to the floor like when everything was plugged in.
With the engine off pressure builds up and holds, but when I crank it over to start the pressure vanishes and won't build up any at all. I have pulled a hose off the booster and it clearly holds a vacuum when it's running. I've jumped the tester for it and only get the code "17" for Reference Voltage.
I hear that air in the brake line would make it spongy but I don't get any pressure so I don't think that would be the issue right now. Any clues as to what I can do to correct my issues?
Source for codes were obtained here: http://www.explorerforum.com/forums/showthread.php?t=258803
