Wolfhound
- August 26, 2008
- Stacyville, Maine
- 2002 Sport Trac
I have a 2002 Ford Explore Sport Trac 4.0 with a problem I cannot find. There is no fuel pressure coming to the motor. The Fuel pump assembly with fuel pressure regulator is new, the fuel filter is new, all relays have been checked, all fuel lines have been checked, test fuel cut off switch, and the fuel rail and injectors have been cleaned. I am a mechanic and have been boggled by this mystery. My last idea is it could be the ECM. Pump was test and puts out 55 to 65 PSI no problem when powered directly. Anybody have any ideas on something I have overlooked that controls power to the fuel pump to cut out.
Thank-you.
Thank-you.
