no overdrive | Ford Explorer Forums
no overdrive
exploder10
union city,tn
2000 explorer Eddie Bauer
In need of some help. I've got a 2000 explorer with the 4.0 and 5r55w with 4405. First off it will shift into rev 1 2 and 3 but I have no 4th or of. I've been told that maybe the speed sensor or transfer case could be causing the problem. O and I've already put another transmission in and did not change any thang thanks
No check engine light but od light flashes
The flashing light indicates a stored trouble code. Have the computer scanned to find out what the code numbers are. A system fault will prevent overdrive from engaging. Your transmission has a "virtual" 5th gear.
