NO Park or anything/new transfer case | Ford Explorer Forums
sapogmxr
!!Drink Beer in Jersey!!
Edison, NJ
'97 Explorer XLT
I just installed a rebuilt transfer case on my truck. I drove it for about 2 miles. I brought it home and i was gonna take the truck out again and it drove about 2 feet and just reved. I went to go put it in park and it rolled. I have installed a new shifter cable aswell. Does anybody know what my problem could be??
Bump
It is clear that your transfer case is disengaged..... I mean the transmission will not roll in park, and if you just rev you obviously lack engine/drivetrain engagemewnt. Occam's razor says the obvious answer is usually the correct one.
Now I realize you are in effect asking what might be wrong with the transfer case... that I cannot answer, other than to say your problem likely lies therein.
assuming that the new transmission cable u put in isnt the problem, are you able to move the transfer case to 4LO? and if so, will the truck roll on its own power then?
if not, then maybe the shift fork is broken..
but first, i would remove the shift motor and see where the shift rod is pointing to. tho the transfer case cant be put into neutral from in cab (via the switch), there is a 'neutral' position in the BW4405 transfer case (if u remove the motor, u'll see that there's an N position). make sure the shift rod isnt pointing to this position.
