No Power at all after replacing shift cable, 2002 XLT | Ford Explorer Forums
DarkLoki
2002 Ford Explorer XLT
Hello,
Hope I'm posting this in the correct place. There are many threads similar but none that Ive found address my particular issue. I have a 2002 Explorer XLT. The shift cable went so I replaced it myself. When I put it all back together the ignition turns and all but there is absolutely no power whatsoever from a fairly new battery. It's like it has no battery, and doesnt respond to a jump.
I DID disconnect the battery prior to working on the column, cleaned all the connections, etc.It was running great before I messed with it. Ive since checked all connections, there is a big green connector to the right side of the column under the dash that has nothing in it but everything else is connected and I'm not sure it ever was connected to anything. I have also checked all the small blade fuses under the dash and all the accessible fuses in the box under the hood on the driver's side. Dont know what else to check but I'm sure it's something I did while replacing the shift cable. Please help and thanx in advance.
CHeck you ground connections, especially battery to block, and block to chassis, both to the frame and the body. Sometime the shifter cable becomes the chassis ground when the other ground connections become bad, making the shifter cable also break.
Thank you for the reply. All the grounds I can find under the hood look secure and clean.
Also, everywhere I recall where the cable met the chassis it was either insulated or embedded in a plastic clip. Not trying to be ungrateful, just trying to understand. Thanx again.
Check for corrosion between the battery cables and their terminals...
Thank you for the reply. I thoroughly cleaned all battery cable connections when I disconnected the battery at both terminals. It's the first time I worked on this vehicle so it's something I just do whether it needs it or not. Was pretty clean.
