csturner92
- November 22, 2013
- Ballwin, Missouri
- 1994 Ford Explorer EB
Just finished changing valve cover gaskets. Removed a lot of parts / hoses and finally put it all back together.
I took off...
Negative Battery Terminal
Alternator
Coil Pack
Upper Intake Manifold
Compressor
After I put everything back together I went to start the engine to check to see if the oil was going to leak. When I put the key in and turned it, no lights came on, No ding, nothing. No power whatsoever.
Went back and double checked the terminals on the battery and they're fine. Posts are spotless and there isn't a hint of corrosion.
How can I find out where the issue is, so I can get this fixed?
Need help ASAP
Additional details:
This is a NO CRANK, NO START issue. Nothing happens when the key is turned. I have checked headlights, power doors, ect and nothing works. I took off both terminals, scrubbed them even though they were clean, and still won't start. Negative is grounded to the frame.
I don't think the battery can die if the negative terminal is off, though I could be wrong.
I took off...
Alternator
Coil Pack
Compressor
Need help ASAP
Additional details:
