stx4.0
- January 17, 2009
- ohio
- 94 sport
I've had 2 explorers now that do the same weird thing.On a cold morning you will get in and start it up and then when you go to take off if you stall it like I did this morning because of the heavy snow built up around it it will absolutely refuse to fire back up..really aggravating to say the least.Now if you let it sit for an hour or two it will fire back up no problem.This obviously has something to do with the choke but neither of my explorers have ever threw a code on this so I assume all else is good I just don't understand why it won't fire back up.Now a guy at ford garage told me last year it is because of the "batch fire" system and said it can be an annoying issue on explorers with a clutch?Does anyone know if there is another cause of this problem that can be fixed or at least made better?I should add all the ignition parts on this is fairly new.It has an accel coil pack which probably isn't any better than the original but also has new wires,plugs etc and compression is excellent so all else shouldn't be an issue.Its hard for me to believe a computer controlled vehicle would have issues with the choke if all else is in good shape.
