nashka
- January 9, 2011
- Panama City, Panama
- 92 eddie bauer
Transmission would not shift up and eventually tore apart to find the problem. Found out the torque converter was from a ford arostar. everything in the valve body was stuck from the grime and metal shavings. Cleaned and inspected everything. Only damage was with one set of clutch plates, for which i replaced both stators and rotors. Installed new another rebuilt torque converter, and seems to be fine except that it will not go into reverse now. A problem that didn't exist prior to the teardown. Any suggestions???
