Ilikemice
- July 6, 2009
- Midlands
- '99 XLT
I'm having yet another problem with the Ex...
It won't start. It happened to me Friday evening when I was trying to get home from work. The starter would work but I'd get nothing. I was getting spark, but I couldn't tell if the fuel pump was coming on or not.
An hour later the AA guy turned up and the car started fine so I drove home. The anti theft light stayed on the entire journey.
I try to start it yesterday and it cranks but doesn't start. I give up.
I try again today and it still won't start. I decide to recharge the battery after much fruitless cranking. An hour later I decide to try again and it fires up fine. It starts no problem over and over. This is where I'm at now.
The theft light is giving me a 121 code. It flashes three times then the light stays on. It does this when the ignition is on and when it's running, and the times when it decides not to start. What's the 121 code? The only reference to it I've found is an old unreplied-to post from a few years ago. The 121 engine code is something to do with a bad TPS apparently.
I guess the light is something to do with the no-start... I'm also guessing it could be fuel related. Is there any way to test if the fuel pump is working? I can't hear a pump noise even when it does decide to start.
Cheers!
Cheers!
