Happy Jack
- June 5, 2004
- Wichita, KS
- 94 Sport
1994 4.0. My son pulled it a part. The AC compressor was leaking and blew oil on the front of the engine. We cleaned upper and lower intakes. Installed the new gaskets with problem solver parts. Found and replace a bad vacume line from the purge valve to the throttle body. Installed new o-rings on the injectors. Injectors all read between 15.7 and 16.1 olms. My son thought he pluged everything back in but it won't start. Cycled the fuel pump about 50 times. Have fuel to the rail. But for some reason no spark at the plugs. He did unplug but did not remove the CPS. A bolt was dropped and ended up in the crankstaft sensor but the battery was disconnected. Coil pack is plugged in. New AC compressor is on and has oil in it but not plugged in till we can get it charged.
Any ideas? Any common mistakes with this we could have made? Back up this evening to look stuff over again in the day light.
