JohnA
- May 10, 2010
- Southeastern PA
- '95 (2 door) Expedition
Vehicle is a 95 2 door Explorer-Expedition. It is basically an Eddie Bauer. It has the audiophile JBL sound system with front/rear speakers & sub in the back right corner. All equipment is 100% original, with no modifications; I am the original owner. Problem is white noise that comes across right rear speaker ONLY. I have switched speakers in rear; noise stays on right side. Both front channels work fine. Symptom occurs with radio or cassette as audio source. The noise level remains constant--not a function of the volume. It seems to be time/temp dependent--as the speaker is fine for first 10 min of use, then the noise abruptly starts & completely takes over the right speaker. I visually inspected the right wiring harness at the rear right speaker & all looks OK--no obvious shorts/opens. This began suddenly about (1) month ago. I have not had any electrical work done recently on the vehicle; there have been no other issues with the vehicle. Any suggestions would be welcome. Thanks.
