Noises!!! Its Killing Me | Ford Explorer Forums
kdogg212001
stockton, california
94 xlt
OK makes no difference if i am off road or on the asphalt i am getting this noise from the driver side it sounds like loose metal bouncing around back and fourth but i cant figure it out i mean everytime i get out to check and see what it is i tap everything and no rattle maybe it could be something inside the hub?? its weird any suggestions on what to check??
Does it do it only when you step on the gas, or the truck in under load? If it is, it could possibly be pinging/detonation in the engine. It sounds like a metallic rattle. I just cleared up my detonation problem by running 93 octance and soon I'll be doing a full tuneup to hopefully use 87 again ( 93 = $2.25 a gallon here). Anyway, let me know and I can probally help you further.
ok its not under any load, no pressure just rolling down the street or trail its just a raddle like a heavy raddle though nto just a screw or something!!!
Radium Arm bushing maybe?? Either that or cat heat shield? Radius arm bushings are hard to tell but will make that noise if failing.
check the bottle jack it gets loose after time and needs to be resecured
whats the bottle jack wheres that located?? ?
lol in the trunk usualy behind a plastic door...its the jack you use to lift the truck and replace a flat tire bro.
