kingoftheplanet
- November 30, 2010
- Romulus Mi.
- 1997 explorer sohc
I have a 1997 explorer sport 4X4 4.0 sohc that i recently (within 2 weeks) have put a new fuel pump,,fuel filter,,injectors,,valve cover gaskets,,air filter,,intake gaskets,,i also have cleaned the MAF and fuel pressure is in spec is at a solid 35 with vacuum line on regulater and 40 with it off..i did the propane vacuum leak check and cant find anything. cant hear a vacuum leak either..it only has the lean on bank 1 ,,PO171 code..after half throttle it bogs but after a couple seconds will start making power again..fuel economy is suffering bad...like 200 miles outta my last full tank....I'm mind boggled by this problem and am lost..i need help bad because its just eating me up,,and i know there are alot of professors of the explorer on this site..any help would be freaking awesome...THANKS IN ADVANCE :exp:
