- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
For a noisy lifter, you replace it with a new one, and this sounds like a minor valve cover noise, not perfectly quiet but not loud enough to worry about yet.
Given the SOHC valvetrain issues, I'd do the two external tensioners and hope the unseen plastic guides are okay. That's the best first step for most all SOHC engine noises. The washers for those tensioners are not magic, but absolutely required. There will be a big leak without one, but the old one can be used, it's just a flat sealing washer, the surfaces being clean and flat are most important.
If the noises are still notably loud after new tensioners, then the choices get more expensive and troublesome. Hopefully you won't need anything else for a while, but expect to be needing the chain cassettes soon enough.
BTW, when removing the front tensioner, do not touch the two sensors mounted in the thermostat housing. Those will leak if you disturb them, so don't push against them to loosen the tensioner, and don't loosen them at all. When they get disturbed, then you will have to replace the entire thermostat housing, so don't mess with those at all. Take it off as one assembly.
