noob lift question | Ford Explorer Forums
noob lift question
disconnects wont lift it. just crank it and be done with it.
Disconnects will not lift it they will just give you alot more flex.
The torsion twist is easy to do. Do a search for torsion twist or TT and I think there is a how-to on this site for it. Try checking the useful threads forum, that's probably where it'll be. But after you're done, make sure to get an alignment. Good luck
I read through the threads and I still have 1 question. Is this suppost to be done while the front end is in the air, or on the ground?
You can do it either way but its easier if its in the air plus less stress on vechicle ;)
