maroon93limited
- October 26, 2008
- Taber, Alberta
- 93 Limited
Thought I'd post here as there seems to be a great deal of knowledgable people in here! Got an 86 Ranger given to me, 2.9 5spd. CANNOT get fuel to the rail. Granted the truck has been sitting for some time, but what are the odds that both in-tank pumps (dual tank truck) are shot at the same time? The high pressure on the frame rail is coming on, but can't hear either of the tank pumps. The selector valve could be shot but I have both tanks nearly half full of fresh gas so it should be pulling from whichever one it's stuck on.
Battery was accidentally hooked up backwards, little puff of smoke from somewhere near the starter solenoid for the 2 seconds it was on there but didn't seem to blow any fuses. Does the fuel pump relay control the high pressure pump as well as the in tanks? Fuseable link perhaps?
Also, the truck does NOT have a canister style filter after the high pressure pump, only the cartridge style in the housing between the selector valve and pump, which I promptly broke trying to remove from the lines. Would it be possible to replace the housing with two canister style filters?
Sorry for all the babbling, but I'm just not too sure where to go from here. I was thinking of just going ahead and replacing the tank pumps, but if there's other areas I should be looking into I'd love to know where to start. I guess I could start with getting 12 volts directly to the pumps to see if they're shot.
Any suggestions?
Any suggestions?
