wilkin250r
- January 13, 2004
- Reno, Nevada
- 93 Sport
Ok, I did what I was supposed to do, I started with the search button, and I came up with a few brand names such as Eaton or Powertrax, and terms I'm not familiar with. Most of the threads started getting to technical for my level of knowledge, so I need to start at the beginning.
I have a 1993 Sport 4x4, manual transmission. I am toying with the idea of changing my gear ratio from my stock 3.27 to probably 4.10 to aid in towing, and prolong tranny life if/when I lift it and get bigger tires.
While I am doing it, I may as well swap to a limited-slip rather than my current open differential.
Do I need to swap the entire rear axle to get limited slip, or can this be done with just gears when I get them changed?
I'm not too concerned about the front LS or open, just so long as I get the gear ratio to match.
What are my options? Brands? Projected costs? Websites with information will be highly appreciated. Also, last I checked, I was quoted about $1600 to change the gear ratio on both front and back, does this sound right to you?
