Yeah but the FPR checked out OK. Your saying replace it anyway? Why?
Don
I think this offset wear problem is more common than people think. It should be noted that at idle and coming to a stop are the two highest vacuum conditions where the regulator opens the widest. At that point it is prone to sticking open. Problem is the ECU will try to learn the new condition and then it will change again. I just wouldn't rule it out when strange things happen with a high mileage vehicle or you get a new pump.
if you wanna check for vaccum leaks there is a sure fire way....get some soapy water in a spray bottle and with the engine running spray around the intake and various areas that could be suspect. if that stuff starts to bubble up you've got a leak. with your rpms running that low i seriously doubt its a fuel problem....if i were you i'd go to Pep Boys and get their gasket kit that has two valve gaskets and the lower intake manifold gasket. replace them all of have em replaced. the kit is like 40 bucks. and not really that hard to do couple hours at most.
I just noticed something on the way home from work! When the engine is running rough, the gas peddle seems to stick. When the engine is running fine, it feels loose! I dont have to push as hard.
What ever this may be, it's been driving me crazy!!!
Have you tried doing a code scan on the computer? Especially if it is an OBDII system, (they sometimes store "soft codes" that don't set off the check engine light, or the light goes on once, trouble code is then stored, and the light does not go off again.) Getting a trouble code scan done is definitly a good idea and could save you a lot of money. Most shops will charge you 40-50 bucks to do a code scan, and it only takes a few minutes.
I just picked up a Actron code scanner from Advanced Auto on Fri. I havnt had a chance to use it because of all the rain we've been having! Im not sure if it's a OBDI or OBDII? The guy just handed it to me and said this is the one for my X.
