o 2 sensor bank 2 ? | Ford Explorer Forums
o 2 sensor bank 2 ?
whitch side ? ?? 97 sohc
First I must note there are 2 02 sensors per side.
sensor 1 is closest to engine, sensor 2 is behind primary catalytic converter.
Passenger side ( right side) is bank one
o2 sensor 1 bank 2 would be the sensor right under the transmission area. Check its wiring first, as it can come loose and rub on the front drive shaft.
