xlt03
- April 22, 2009
- Bay Point, CA
- 2016 Sport
O/D Light Blinking and P0732 - SOLVED!
Got the dreaded O/D light linking. Used Innova 3150 Scanner and pulled P0732- gear 2 incorrect ratio
Took vehicle out for test drive and here's findings:
If I select each each gear on a flat road I have first, second, third, fourth. O/D is unknown since light is blinking.
From a stopped position on a hill going up hill and I select :
1st gear the vehicles moves up the hill. I let off the gas and vehicles rolls backwards a bit.
2nd gear the vehicles moves up the hill but takes more gas/throttle. I let off the throttle and vehicle does not roll back and vehicle feels like it's stuck with the parking brake applied. If I give it some gas, it moves uphill and when I let go of the throttle it feels like it's stuck again.
3rd gear the vehicles moves up the hill but takes more gas/throttle. I let off the throttle and vehicle does not roll back and vehicle feels like it's stuck with the parking brake applied. If I give it some gas, it moves uphill and when I let go of the throttle it feels like it's stuck again.
4th gear (D) the vehicles moves up the hill and when I let go of the gas, the vehicles rolls backwards a bit.
If I go downhill and downshift from 4th(D) to 3rd gear I feel if shift to that gear, same when downshifting for 3rd gear to 2nd gear, and same from 2nd to 1st gear.
History of vehicle: I'm the original owner. 2003 Explorer 4X4 4.6L; 5R55S transmission, Door sticker Trans code is V. Axle is D4. Current mileage is 126,250. Transmission started at 88,000 miles to have delayed reverse engagement when cold and shuttered a bit but engaged. Changed fluid and filter at 88,000 miles, drained pan, replaced filter only. Did not flush. Morning reverse shuttering continues. I figured it needed to build pressure to engage.
No transmission leaks. This is the original transmission.
My thoughts and proposed plan:
Drop the pan and inspect contents. From what I read from BrooklynBay I may or may not find a servo/band strut on the bottom of pan; I'm thinking not since I seem to have all gears and if so then pull the solenoid and do the resistance ohms test. If OK then drop the valve body and check band for breakage. Pull the servos out of the sides of the case and inspect the servos and servo bores. If bore(s) are elongated I'll buy the servo bore pistons fix from www.fordservoboretransmissionfixsolution.com. If the bores are OK I'll replace with new pistons and new o-rings on the caps.
How do I check/inspect the valve body? I may have missed a link in searching for my solutions for the blinking O/D light.
P0732 would suggest something is mechanically broken but I'm thinking not since I seem to have all gears. Am I mistaken?
Your thoughts, comments, experiences and suggestions are appreciated.
