skipc10
- October 17, 2003
- Brookfield, GA
- 96 4wd 4.0L XLT
This one may need a real tranny guru!
Got a '96 4.0L, 4WD auto (4E55 trans) and it works great, except the o/d shutoff doesn't want to work. Changed fluid and it was fine, as was the pan, etc. Changed fluid regularly, now has 115k on it. Shifts fine, etc, except for the past 50k miles it doesn't seem to want to obey the o/d off button. If I play with the cooler hoses, or if it's very cold out, it will more likely work, but as it gets warmer it doesn't want to turn off again, or turn on. A shutdown and restart always resets it to o/d-on as it should.
Tried overfilling and underfilling the fluid, but at most it might get it to work for one time out then it's non-responsive again. It has a cooler I put on when new. It will almost always work once if I open the line to do something to it. I've tried openning it just for that reason and it will work once, but that's a little tough to do every startup
My books have MOST of the wiring info EXCEPT for this button, and whether it goes to the computer or directly to the trans. It doesn't 'feel' like an elctrical switch problem, it's more running and temp related.
Can anyone give me guidance on figuring this out, like what affects that part of the tranny operation, likely causes, how it's wired up, sensitivities to things like fluid level (like it wants extra fluid as it gets old or something), etc in this type tranny? Other than this it's great, no codes either. I want to tow with it now and I'd like to keep it from going back and forth into O/D when I do, so now I need it....
Please cc my email if you can with replies.
Thanks in advance.
Thanks in advance.
