Antonkov
- May 20, 2006
- Vancouver, BC
- 97 XLT
Long story, will try to make it short: I bought my ’97 Explorer with no clues of previous service history, everything worked more or less fine but gas mileage could have been better. I thought the car is 10y.o. and it wouldn’t hurt to change the spark plugs and wires and to replace the front O2 sensors. Changed, didn’t get any noticeable improvement neither in power not in mileage, then, in a month or so my MIL lamp went off.
The codes were:
P1130 - Lack of Switching – Bank 1, sensor 1
P1131 - Lack of Switching - Sensor Indicates Lean, Bank 1, sensor 1
Then I started noticing some engine vibration, which kinda comes and goes from trip to trip. The power went slightly down but the mileage increased. I checked the passenger side sensor, it looked fine (no any buildups or greenish stuff from the coolant, if it leaked).
Then the MIL lamp turned off by itself and several trips later came back on….
I bought LM237 interface and tried to check what goes on inside - all four sensors read 0V, both fuel trims are at -100%, fuel mode is in “Closed loop with a sensor failure”.
I remember someone said on this forum that if one got two sensors died at the same time, he should not leave his house coz of high chances of being struck by lightening, I had four silent sensors, scary….
I tapped into the signal wires of bank2 sensor and checked the voltage with a digital voltmeter; it jumped from 0.3V to 0.7V on the voltmeter but still 0V on the software scanner ( I used ProScan).
My questions are:
1) Even if my B1S1 sensor IS dead (going to play with it tonight) the other one MUST be alive - first, because I saw it breathing on the voltmeter, and second, because how would it enter the closed loop with both sensors reading 0V ……so if B2S1 is still good why can’t I read it with a scanner?
2) Is it possible that PCM failed some high level test and doesn’t report out O2 reading although uses them internally?
3) If the sensor IS dead, why would MIL lamp go on and off from trip to trip? Is it like it is “almost” dead but still reports something under certain modes?
Any ideas are much appreciated!
The codes were:
My questions are:
