alg
- March 27, 2013
- jacksonville, fl
- 2002 explorer xlt
I have a 02 explorer slt. I get the following codes: P0301, P0302, P0303, P0353.
I checked the primary coil pack and get identical resistance readings.
The secondary readings are all 13.5k ohms. The shop manual says range is 6.5-11.5k ohms.
Since my scanner shows cylinder 3 issue I checked the resistance in that cylinder wire and it is 9.5k ohms. That is good as normal is 5k/ft of cable.
There is great spark on that cylinder with a test light.
Except for the secondary coil readings which are higher than specs (but all readings are equal) I don’t know if the coil pack is an issue.
My questions are; are the secondary coil resistance readings an issue ?
What should I investigate next, if I get feedback that the coil pack seems ok. The vehicle is not drivable as it stands.
Thanks for your feedback.
