goldfinger1003
- November 30, 2009
- South Jersey
- 2003 Ford Explorer
My 2003 Ford Explorer, 4 door, automatic, 4X4, has started not shifting properly and the "OD off" warning light keeps flashing. After scanning to find out what the problem might be; one code came up which was "P0775". I then took it to a local shop. The mechanic seemed to be very familiar with this type of problem. He said he would check the wiring in the steering column, and also leading into the transmission. Later that day he called and said because he had not found anything wrong with the wiring he would have to remove the pan to check and see if metal shavings present, and what the condition of the fluid was. The next day he called to break the bad news that I needed a new transmission and quoted me a price of $3500.00. My question is; if the code "P0775" indicating a problem with the "Pressure Control Solenoid B Circuit Malfunction" came up, wouldn't he address this issue first? I have very little faith in some auto mechanics. How can I be sure he is not trying to take me for a ride?
