360cid
- July 3, 2010
- Snohomish Washington
- 2004 Explorer XLT
I was doing an inspection on the front end of my '04 of the brakes because I heard what sounded like a worn out pad squeak on the left front. Pads looked good, almost 3/8" on both pads, same as right front! Rotors looked good, no scoring and no sign of warping. Did not measure thickness of rotors though! What I did notice was on the right front. Rotor seemed much more dificult to rotate than the left! Could this be because it has an open front diff and not a posi? Don't know what to make of it! Changed diff fluid a couple of weeks ago with Redline 75/90 with the friction modifier, but don't know if that made any difference before or after. Does not pull from one side or the other when driving straight or when the brakes are applied!
