ponkotsu
- October 29, 2012
- Colorado Springs, CO
- 2005 Lincoln Aviator
Seems like this keeps getting worse. I've got a rough and hunting idle. I've checked everything:
Plugs
Coils
Spark
Vacuum leak
O2 Sensors
Cleaned throttle body
Cleaned intake. Upper and lower.
New OEM IAC
PCV system is functioning correctly
So today I connected to Scan XL. With this tool I was able to confirm that my O2 sensors are all working correctly.
But based on troubleshooting theory, it says I've got a pretty good vacuum leak. Long term fuel trim is 10 - 20%. When I raise RPM to 2k, the long term goes to zero and short term goes high. It's got pretty equal percentages on both banks. That's text book intake vacuum leak. So I smoke tested again. And again. I've put hose clamps on everything that even seemed like a leak.
Only thing left is EGR. It is leaking, but only very slightly. From videos I've seen on youtube, the small amount of leakage is pretty normal.
I did the garden hose test also. I was getting what I thought was a reaction at the rear of the left cylinder head, but it was hard to tell. Can't imagine anything leaking there other than the head gasket, and that would only cause a lean condition on one bank.
If anyone has any ideas of where a vacuum leak could hide let me know!
Plugs
Coils
Spark
Vacuum leak
O2 Sensors
New OEM IAC
