teletekman
- July 16, 2012
- Madera, CA
- 1992 Ford Explorer XLT
Hi,
I have been told recently that I should install an OEM Motorcraft fan clutch on my Explorer replacing the Hayden Severe Duty aftermarket I bought at Oreily's for my 92 XLT Automatic w/ AC. My Severe Duty clutch seems to be working fine for how it is designed but for what they are recommneded for, especially towing in higher temp environments, I don't think I need one so beefed up. Plus the higher spinning of the fan and lower MPG's I seem to be experiencing with this clutch, not too mention my explorer sounding like an 18 Wheeler is driving me nuts.
I can't find an aftermarket clutch that is not Severe Duty unless I get the manual tranny clutch which is Standard Duty.
So I'm looking at Motorcraft clutches and an confused on the options listed. They have a Super Cooling package and a Base Cooling package clutch. The Super Cooling package clutch has a considerable price difference.
What is the difference between the two?
I was told the Super Cooling clutch is needed if I have the external tranny cooler which I do and others have told me that the Base Cooling clutch will work just fine. Both types say they will work on a Automatic w/ AC. So is the OEM Super Cooling clutch the same as the aftermarket's version of Severe Duty? Does anyone know if there is a aftermarket clutch that is not Severe Duty for my Explorer?
Thanks in advance for the help.
Sean
Sean
