natenkiki2004
Blue Bomb!
- November 3, 2013
- Location
- North Idaho
- 1991 & 1994 Explorers
If it was a leak, you would notice it. I was losing about 1.5 quarts in 400 miles from my oil pan and everywhere I went there was a basketball sized puddle. It actually ended up being a drip every 5 seconds. Granted yours isn't as bad but if you idle the engine and don't see any drips underneath for 30 seconds, it's time to look elsewhere.
If you get a puff of smoke when starting, that's definitely valve stem seals.
Try a trick; find a long and somewhat steep hill. Put the trans into first and wind it up then let off the throttle. Let gravity keep the RPM's high. This will generate an above-normal vacuum in the engine. When you get to the bottom, pop it in a higher gear and take off. You'll need a spotter at the bottom of the hill to watch for smoke out the exhaust. If there's a significant amount when you hit the throttle at the bottom, that can be a good indicator of rings going bad.
