What is 4.0 ohv normal oil consumption?
Karpov
Finland so my english is bad :D
Explorer 4x4 '93
Near 200k miles on my one.
It wont give any blue exhaust smoke at any situation or leak oil.
I think it swallows little bit too much...
5w30 semi syn ford own oil now, before 5w40 full syn.
I change oil about 1000-1500miles ago and it was top of full mark. Today check oil bulb lights on and i check oils. Was in low mark. So about 1 liter or quart per that range?
Maniak
Moderator-Stock 91-94
Moderator Emeritus
Vail, Arizona
1992 XLT 4x4
Now our X uses less than 1/2 quart every 6-8k miles..
Before we rebuilt it, it was using 1 quart every 4000 miles..
I don't know if it is/was more using, or leaking but it was rebuilt at 355k miles when I got sick of the milkshake in the cooling system (cracked head).
Also, IIRC, the oil level light comes on at 2 quarts low, not 1 quart..
~Mark
Benjam
WI
92 XLT Stick,4x4, 422 cam
I suggest re-torquing your lower intake bolts in the proper sequence. Very common for them to loosen up and start burning oil. Pull the number 5 spark plug and look for signs of oil. Worst case is you're out a little time and it doesn't do anything for your consumption..
Benjam :D
Karpov
Explorer 4x4 '93
Hmm i check that.
Thats still weird because i have been many cars with bad valve sterns and theyre allways but little or more blue smoke when you start etc.
This isnt giving blue at no situations so it doesnt burn it much on chamber.
Coolant is good like oil too, no mixing.
New vag consern shit cars use easily 1-2liter per 1000km and its normal and you dont get nothin from dealer about that...
Is that crosshatched area 2 quarts?? Ive been thinking that its 1.
Because when check oil comes, its just liiitle under from that crosshatched area.
arco777
1994 Explorer 2dr 4x4
It seems to vary depending on how the engine has been maintained and used over its lifespan. One of my Explorers will burn about 1/2 a quart every 3000 miles; it is at 195k. The other doesn't noticeably burn any and is at 185k.
From my experience the 4.0 does not mind being overfilled a little. I used to run a quart over the normal capacity without any problems.
colintrax
Georgia
97 XLT
Mines a quart over right now. At 180k I burn none. Full syn 5w30
