- March 3, 2002
- Elkridge, MD
- 04 4Runner, 22 Silverado
Just changed my oil today on my X. After finishing up, I started and I could hear a noise from the engine compartment. So I shut off the truck to investigate and when I looked underneath, I notice it was leaking oil around the filter. It was only on for maybe 5 seconds before I shut it off. I figured maybe I didn't tighten the filter enough even though I did it hand tight. So I placed a wrench on it and turn it about 1/4. Started it back up and it was still leaking so I went back underneath and starting draining once again. After going through the oil change for a second time, I checked it for leaks and stuff and it was fine.. I let it run for a good 15 minutes. The only thing I noticed was smoke from the oil being burned on the pipes. Upon further investigations, I looked at the oil filter and low and behold the rubber gasket around the filter had a slice in it. Could this have caused the oil to leak and does anyone think any damage occured when I started it up the first time or the second time. I'm seriously thinking about contacting the manufacturer of the filter to see what they will do. The cut in the gasked is very apparent. I just wish I noticed it first before I put in on the engine.
