srvblues00
- November 22, 2001
- Denver, NC
- 94 Sport / 88 Turbo Stang
the last time i went to change my oil, i got valvoline max life, and a motorcraft FL1A filter. that filter is spec'd in the owner's manual. i drained the oil, took the old filter off. then i stuck the new FL1A filter on there, stuck the oil drain plug back in, and filled 'er up. i cranked it to make sure everything was right. i heard something that didn't sound right, so i took a look under the X. i saw oil spraying out everywhere from the filter area. :frustrate so, i took it off, made sure the gasket was on there, and put the filter back on, and tightened it down abotu as i tight as i could get it hand tight. i checked the oil, and only lost 1qt, so i fired it up again just to check the filter. it did it again!! man i was so pissed. i ended up draning putting the old fiter back on there. i compared the threads between the old penzoil filter and the FL1A. the FL1A had about 3 threads and the penzoil had about 8 or 10. any ideas what's going on here? the old filter went on fine and i haven't had any problems with it. i checked another FL1A filter at an auto parts store to see if my first one was defective, but it wasn't. the new one also had the threads like that. what's going on? what filter should i get next? i don't want to lose another $10 in oil.
thx
