bigDerk
- February 11, 2001
- Stockbridge, GA
- 2001 Ranger Edge
Today when I pulled my front wheels to inspect for a grinding noise I've been hearing (found out that my RF radius arm bushing is split, GRR), I noticed that there is a significant amount of what I think is bearing grease or something leaking out from around the front hubs. It is leaked out around the wheel studs and around the outside of the hub cover, and somewhat close to the brake rotor surface. Is this normal?
I noticed that there isn't any sort of O-ring or sealing gasket around the front hubs, should there be?
