oil leak | Ford Explorer Forums
oil leak
chopper_59
jackson , mn
1994 explorer
just wondering how hard it is to change a oil pan gasket on a 94 exploer if anyone out there has done this? the local shop told me it is a 9 hr. job? i could keep putting oil in it for along time for that much. it leaks in the front right side not allot but is a eye sore. any help or sudjustions?
thanks chopper
I just had some oil leaks fixed. One leak was the oil pan gasket. I thought about doing it myself but never found the time. There seemed to be a lot of stuff to take off. I figured I would just pay for it since the rear seal needed replacing also and I have no way to drop the transmission myself.
The Pan gasket is changed with the motor out. You have to lift the motor way up to get the pan off.. and at that point your taking the motor out...
~Mark
Pep Boys did it for $800. I didn't even shop around. Kinda kicking myself for not doing so. $800 was for the oil pan gasket part. I was tired of putting in a quart every two weeks. Sometimes once a week if I drove it more.
If you can hold the engine with a jack, you can unbolt the mounts & jack it up to clear the cross member. However you need to make sure eveything is disconnected so nothing catches. The tranny will have to be unbolted & moved rearward, or removed. You also need to take the hood off for clearance.
I've been researching it since I have a leak also.
Something to try that has helped me. Try to tighten all the oil pan bolts. There were a few on mine that were a little loose. This stopped alot of the seeping I got.
Also I don't know if this can be done but could the front cross member be taken out? Then it's an easy shot to the pan.
i just fixed my driversside valve cover leak, i had little holes rusted through around the bolts. there's a lot to take off of that thing.
<snip>
At that point you have basically pulled the motor.. All that is left is lifting it.. and you might was well use a hoist to hold the motor up as you do the work on the pan and change the oil pump since your there..
~Mark
it looks to be some work thanks for the input from all of you it is almost time to get the harley out for the rest of the year around here as long as we don't get another foot of snow. this will have to be a summer job :exp: that is for sure
chopper
