Capt Robert
- March 12, 2009
- Cocoa Florida
- 1997 XL, 97 XLT, 02 XLS
Hello all. I have a 97 explorer. SOHC V6. I noticed the check gage light came on and the oil pressure needle was at 0, the bottom of gague. I shut it off and then restarted it. The gague returned to normal. Few minutes later, same thing again. I had just changed the oil, using the same type of filter as always. A Fram sure grip PH8A. I dedided to take the bottom oil pan off and inspect the oil pick up screen. When I took off the lower pan I found what the dealer describes as timing chain guide parts, along with other various pieces of metal and plastic. I cleaned out the screen and put it all back together. Same problem. It starts and runs perfect, no missing no smoking etc. If this wasn't the best vehicle that I've ever owned I wouldn't bother with it, but even after 244k + miles, well even the A/C still works great.
I read something about an oil filter check valve? Can anyone expande on this as a poss cause. I understand that the metal and plastic parts that I found will lead eventually lead to a major repair, but That isnt effecting the oil pressure. It is still running strong and smooth. With its age and milage, I don't want to put a lot of money in it. If I cant figure this out then I'll have to sell it. Any help will be appreciated. thanks Rob
