Safety note
I'm about to go on a rant, so bear with me.
Today I went back and took my razor scraper to the mating surfaces of the block and head, block and timing cover, then proceeded on to do the same thing to each head, 3 sides scraped excepting where the rocker covers go on. After this, I wiped all of those surfaces down with paint thinner, to remove any residual bits of gasket. Then, I went and checked the fit of the oil pump driveshaft at both ends, and they both solid, with no play. That points directly at the oil pump pickup being covered with goop. Then, I took the pickup, and sprayed the screen with brake cleaner, guess what? The screen came back and was shiny again! All of the crap that was on it went back up the tube and out t'other end.
Now, for the rant. If you happen to see a low oil pressure reading, it might just be a wonky sender, or it may be a partially blocked oil pickup screen. So, drain the oil after warming the engine up, and once the drain is clear of drips, take a
flexible LED, available at
http://www.harborfreight.com, and see if the oil pickup is visible to the front and left of the drain hole. You may only see the pickup's metal parts, but it is only thing that should be in the pan aside from the baffle on the crank journal caps. You can try to clear the screen by dumping something like Varsol, or paint thinner, or mineral spirits, a quart or so, into the filler with the drain plug back in. Let that sit, overnight, and drain that out the next day. Reexamine that which you saw, and if it hasn't improved, then do it once more, dumping what remains of the gallon of *solvent*, not cleaner, that you got into the filler, again , drain plug back in. Let it sit overnight again, and repeat the exercise of the previous day. This time, there should be something visible, and you can use a spray like brake cleaner to break up any additional blockage on the pickup screen. Mind, be prepared to fill the crankcase with a very cheap oil, and filter, changed after you have the engine warmed up again. Tranny fluid can be used to help clean, but don't drive anywhere or put any load on the engine - idling for 15 minutes, if the oil pickup is clear, should do the trick for cleaning the engine inside.
***Make sure that you are wearing some type of eye protection, in case some of the solvent drips into your face***
Whatever you do, make gorram sure that the solvent you use is NOT water-based, or it will screw up whatever fluids that put in after it. That is where the malted-milk came from in mine. And, my machinations are likely what caused the garbage to break loose and plug up the oil pickup screen.
As it is said, those that don't learn from history are condemned to repeat it. That is my story, and I'll be stickin' to it.
rant off
