natenkiki2004
Blue Bomb!
- November 3, 2013
- Location
- North Idaho
- 1991 & 1994 Explorers
Sometime in the near future, my engine's coming out due to a severe oil leak, either from the rear main or oil pan. Gonna do them both.
I've been contemplating doing the oil pump while I'm in there, just for good measure. Before getting into that though, I finally got an oil pressure gauge on today. When cold at idle, it's about 60PSI. When it's warm, cruising on the highway between 2,000-2,500RPM it can be around 45-50. When idling in gear at a stop, I saw it dip down at low as 20 but usually 25.
I'm pleased with these readings considering the history of the vehicle (neglect, thefts, etc) and being almost 227,000 miles. I would be happy just sealing the pan up but jd4242 is always talking about the Mellings M-328 high flow pump. Specifically, in this post here:
http://www.explorerforum.com/forums/showpost.php?p=2224198&postcount=7
I could stretch funds and replace my pump with the high volume one. My question is, would it be worth it? I have plenty of other things to spend the $$ on that need doing on the Explorer (rocker arms & pushrods are next...). But, I want this vehicle to last.
Thoughts?
Thoughts?
