veener79
- May 12, 2017
- IL
- 2017 Explorer Platinum
Coming form owning a WRX and reading up a lot about oil and oil sheer from the higher temps it got me thinking about the Explorer. For the WRX I run the Shell Rotella 6T because it can hold higher temps from when the turbo heats up with out sheer. I do track my car at times. In part what helps in the higher zinc content. Also running the 5w/40 vs the 5w/30. I even have to run OEM oil filters because aftermarket ones do not have the current bypass pressure for the turbos need over the NA. Yes Subaru's are that fun at times.
But I know the higher zinc is not great for cats. Is there a better oil to run on the Ecoboost engines verses running on a NA motor? Was going to run full synthetic. I am not sure how how hot the turbos run on the Ecoboost. Its not like I am going to track it. Right now on my WRX I have 144K on the stock turbo. Want to keep that same high life in the Explorer.
Thanks
Thanks
