Not that I did this while working on my truck, I did do some stupid stuff a bunch of times but this one is way to funny not to post.
I was installing a light fixture on the outside of my house one day, to hole I needed to drill was directly underneath the porch roof. I got a 3/4" speed bit (the flat type) and plugged in the drill and started drilling, well as you might know from experience, speed bits tend to catch when they get almost through the hole, so realizing this standing on my tip toes drilling the hole, I released the trigger on the drill when I thought it was close to the end, as I did this the drill kept going because I had pressed the trigger lock. You have to realize the next few actions took place in about 3 seconds, as I realized the drill was not stopping it caught at the end of the hole trapping my hand between the roof and the drill. The drill is now humming because it is stopped with the trigger locked on and my hand is stuck there. I finally was able to remove my hand, and the drill pushes into the hole and begins to spin wide open.
1 second has gone by and I am standing there looking at the drill spinning wildly in the hole. 1/2 second goes by, gravity takes over and the drill starts to fall out of the hole, seeing this and reacting I see the drill turn a 180 and fall, bit towards me, remember the bit is still going about 9000 rpms. I back away by pulling my head back, the drill goes by my face, I'm think wow that was close, 1/10 a second past my face the bit catches the bottom of my shirt, @%$&, the drill, still wide open, the bit grabs my shirt, winds up my shirt and is now to my throat making the same sound it made two seconds ago when it is held stopped but still wide open. Now you have to imagine this, I have both hands on the drill, my shirt is wound up around my neck and I look like some guy in a horror movie with wild animal attacking my throat. Unfortunately I cannot unplug the drill because I used an extension cord for the first time in my life, and if I try to run to the end of the 50' of cord to unplug it, I might suffocate. Another blessing, I later realized, is that I had bought a reversible drill, and in my panic of trying pull the demon possessed drill from my throat, I hit the reverse lever and the drill spun off my neck and then to the ground, still at 9000 rpms. I swiftly kicked the POS and it stops 3 seconds after this little episode begun. Standing there in a complete daze, I assessed the situation,
1. Hole is done.
2. Shirt is peppered with holes from the speed bit.
3. Lift shirt up, no blood, unbelievable.
4. No one will believe this one, should have put the camcorder up, damn
5. This is the truth, I would not post a lie
Don
[Edited by beertime9 on 12-08-2000 at 02:28 PM]
