Isles4evr
Elite Explorer<br>ECX Member
- January 26, 2000
- Mechanicsville, VA
- 91 XL 2dr
When I was messing around the my coil spacers the other day I had noticed that the clips that hold in my coil spring on the top side of the perch were pressed so far in that the spring was next to impossible to get off. I have seen on a couple of setups that there is a clip the bolt in on the out side of the perch and hold the spring in place. Where can I find one of these? And if i do put one on will it be safe to cut off the 2 rear clips on the pearch for ease of the spring comming out (it took almost 2.5hrs to get it out), b/c i still want to put the spacers in as soon as I find a new bolt, and then eventually bigger lift and 4wd... so the spring will be in and out throughout it's life. So anyway any informantion will be appreciated...
Thanks
Chris
Thanks
Chris
