One head light | Ford Explorer Forums
One head light
Danneedshelp
Patterson Louisiana
2019 Explorer xlt
I need some help ,my wife’s explorers light or not working correctly the driver side head light was staying on and passager side don’t come on . So I unplugged the passenger side and now the drivers side timed out and went off and now works normally with light switch and all .There was moisture in the passenger side Assembly . I dried it out with a hair drier and plugged the passenger side back in , but still the lights are not working probably . Passenger side doesn’t come on and driver side stays on.I left the passenger side unplugged for now so the driver side would work normally. Any ideas ? I’m going to change the passenger side bulb tomorrow,but I feel it’s more to it than that .
If the bulb doesn't fix it, you might have to change the assembly. Water and electronics don't mix.
Thanks , that’s what I’m afraid of . I started to plug it back in this morning, but firgured I give it a day in the sun to dry out more . I will see what happens today after work .
Welcome to the Forum. :wave:
Some moisture in the headlamp is not uncommon. These are not sealed beams. Which one is the issue with? The high or low beam? The low beam is LED,
Hello 👋Yesterday the high and low wasn’t working.I got home plugged it in and both light came on , high and low beams but know they don’t shut off . This is weird
Just a update , light is working properly.The light went off after a while and my wife increased light time when going though settings by accident. It appears that water in the plug itself was the issue . Thanks for the reply’s
