does it stall as soon as you shift it in reverse? once you hit the gas after shifting into reverse? ect. that will help pin point things a little more maybe.
first thing i would do is clean the IAC and MAF. but more detail will help us help you!
Hey, do you have a V6 or V8? Last night I found a thread with the same problem, the guy had a V8 though.. seems like we're on to something here. This is new to me anyways.
Does it idle fine normally? Try and get yourself up hill and put it into gear.. does it run fine? Does it bog out? As mentioned before, this could be an IAC issue. Maf would be the next check. Can you pull the plugs and see how they're doing?
