cmhaah06
- March 30, 2007
- CLOVIS, CA
- 91 XLT
as fast as i can i'll tell you the prob....im at work. i was out running around yesterday and ran into this...i parked the expolrer went into a store and when i came out and turned the key to start it....it did nothing.
well not nothing...it made that weird tat,tat,tat, sound you get when ur battery is dead...so i pull out the battery...take it to kragen...tests fine...they never put a load on it but it took a charge.
take the "good" battery back to the truck put it in and still does not start...so, like anyone with a manual tranny i push start the truck and take it to kragens again.
they tell me they can not test the alternator because i have to be able to turn off the truck so they can hook up their computer...so i drive it to my dads we fiddle for about 20 minutes and seems like the solenoid on the passenger side inner fender well is not working...(i had a 91 ranger that had issuses like this and i used to start the truck from the solenoid, after putting the key in and turning it to the on position, i would then touch the two prongs together using a screwdriver.)
so i go back to kragens and buy a solenoid and a starter just because...put in the new solenoid and starter and the thing still doesn't want to start.
we fiddle a little bit more and notice that every time i turn the key to start the vehicle the truck acts like its dead...nothing works...then we "wiggle" the ground cable coming from the battery and everything turns back on...now that i know its not the starter, solenoid or battery i have bought new cables...if this doesn't work does anybody have any suggestions???
p.s. need help asap have a big camping trip with friends in two weeks!!!
