- March 13, 2005
- Martinsburg WV
- 84 BII "Li'l Samson"
I've had my Red top for over 5 years and I'm assuming it's the USA made one? Can't be happier.
Now the move to Mexico does have me concerned, but I like the fact that it is an AGM batt.
I have friend that works at Battery Mart and I'm going to pic his brain about this South of the Boarder move, including the warranty and has he seen a rise in batt. failure as far as Optima is concerned.
This Bronco does see some terrain that it could go topsy turvey and don't need acid all over the place.
Just yesterday a friend of mine had his liquid filled battery blow up in his face requiring a trip to the hospital.
I have several off-road lights that stay on after engine is cut off during the hunting season including a twin 55 halogen work light mounted in rear bed...getting guns out of cases, heavy coats,parkas, tree stands etc.
Never had a problem with that batt.
Also the engine is a built 302 with 10 to 1 compression that I assume would require additional cranking amps.
Not to mention an 8000 Warn winch that I used just a few days ago retrieving game out of a gully. And all this with just a single wire 100 amp alternator.
Might mention that this batt. has never seen a batt. tender or charger.
Now I do have the idle set at 1100 RPMs. One reason is the cam, the other is the single wire alternator likes at least 1000 RPMs to make those volts.
And mounted securely below bed.
