Orifice tube location. | Ford Explorer Forums
sbowman
independence mo.
2002 eddie bauer 4.6
Sam Bowman from Independence Mo.
Need to no where orfice tube is located in my 2002 ford explorer 4.6 eng.
thanks
Sam
Should be in the lower line from the evaporator.
orfice tube
It was in tube going to evaporator!
thank you
2002 explorer orfice tube
Tube is in high pressure line, about 8 IN. from firewall, you will see a fitting
there. Take fitting apart and remove orfice tube with needle nose pliers.
I bought mine at advanced auto for about $3.00,my compressor failed was
reason i replaced tube. Orfice tube was full of metal and i had to flush condenser.
thanks
sam bowman
